Cosa ti serve
Remove the battery, base cover, memory module, and hard-drive assembly, keyboard trim, keyboard [itself], palmrest, display hinge-brackets, display assembly, system fan, and system board from the computer.
Disconnect the coin-cell battery cable from its connector on the system board [1].
Pry the coin-cell battery to release from the adhesive and remove from the system board [2].
Place the coin-cell battery into its slot on the system board.
Connect the coin-cell battery cable to its connector on the system board.
Install the system board, system fan, display assembly, display-hinge brackets, palmrest, keyboard [itself], keyboard trim, hard-drive assembly, memory, battery, and base cover for the computer.
2 Commenti
Do you know if it is possible to upgrade the motherboard during this processor
Sorry for the late response. Yes; it's possible to upgrade the motherboard/system board during this process. You'll just have to check if the motherboard fits your Latitude E5550 as per the sources below.
(Main source: https://www.parts-people.com/index.php?a...
DELL Community source: https://www.dell.com/community/en/conver...).
