Salta al contenuto principale
Dell Latitude E5500 RAM Replacement
Cosa ti serve
  1. Dell Latitude E5500 RAM Replacement, RAM: passo 1, immagine 1 di 1
    • Unscrew the single 3.5mm Phillips #1 screw that holds on the bottom plate of the device.
  2. Dell Latitude E5500 RAM Replacement: passo 2, immagine 1 di 2 Dell Latitude E5500 RAM Replacement: passo 2, immagine 2 di 2
    • Place your hands on the plate and pull it toward yourself.
    • The plate will pop out of place and may then be removed.
  3. Dell Latitude E5500 RAM Replacement: passo 3, immagine 1 di 1
    • The RAM sticks are located near the center of the device, and are arranged one on top of the other.
  4. Dell Latitude E5500 RAM Replacement: passo 4, immagine 1 di 2 Dell Latitude E5500 RAM Replacement: passo 4, immagine 2 di 2
    • Locate the two dislocating tabs on each side of the stick and place your fingers on the tabs.
    • Pull the tabs away from the stick to pop it out of place.
    • Notice the angle it rests at after the tabs have been opened. This is important for installation of new RAM.
    • Once the RAM stick has popped out of place, it can be gently removed.
  5. Dell Latitude E5500 RAM Replacement: passo 5, immagine 1 di 3 Dell Latitude E5500 RAM Replacement: passo 5, immagine 2 di 3 Dell Latitude E5500 RAM Replacement: passo 5, immagine 3 di 3
    • If necessary, repeat this process with the second RAM stick that lies beneath the first one.
Conclusione
To reassemble your device, install the new stick(s) and follow these instructions in reverse order.
Altre 4 persone hanno completato questa guida.
Evan Eldridge
Membro da: 10/20/16
215 Reputazione
1 Guida realizzata
UMass Dartmouth, Team 2-4, Isaacson Fall 2016 Membro di UMass Dartmouth, Team 2-4, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G4
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,153
