Salta al contenuto principale
Dell Latitude E5500 Bluetooth Card Replacement
Cosa ti serve
  1. Dell Latitude E5500 Bluetooth Card Replacement, Bluetooth Card: passo 1, immagine 1 di 1
    • Unscrew the single 3.5mm Phillips #1 screw that holds on the bottom plate of the device.
  2. Dell Latitude E5500 Bluetooth Card Replacement: passo 2, immagine 1 di 2 Dell Latitude E5500 Bluetooth Card Replacement: passo 2, immagine 2 di 2
    • Place your hands on the plate and pull it toward yourself.
    • The plate will pop out of place and may then be removed.
  3. Dell Latitude E5500 Bluetooth Card Replacement: passo 3, immagine 1 di 2 Dell Latitude E5500 Bluetooth Card Replacement: passo 3, immagine 2 di 2
    • The Bluetooth card is located near the front of the device, and is the expansion card with one antenna attached to it.
  4. Dell Latitude E5500 Bluetooth Card Replacement: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the wire connecting the card to the laptop with a pair of tweezers.
  5. Dell Latitude E5500 Bluetooth Card Replacement: passo 5, immagine 1 di 1
    • Unscrew the 4mm Phillips #1 screw that secure the card in place.
  6. Dell Latitude E5500 Bluetooth Card Replacement: passo 6, immagine 1 di 2 Dell Latitude E5500 Bluetooth Card Replacement: passo 6, immagine 2 di 2
    • After completing steps 4 & 5, the card will lift up at an angle as shown.
    • Once the card has popped out of place, it can be gently removed.
Conclusione
Altre 4 persone hanno completato questa guida.
UMass Dartmouth, Team 2-4, Isaacson Fall 2016 Membro di UMass Dartmouth, Team 2-4, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G4
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 29
Tutti i Tempi: 2,479
