Salta al contenuto principale
Dell Latitude E5470 Screen Assembly Replacement
Cosa ti serve
  1. Dell Latitude E5470 Screen Assembly  Replacement, Remove Bottom Cover: passo 1, immagine 1 di 2 Dell Latitude E5470 Screen Assembly  Replacement, Remove Bottom Cover: passo 1, immagine 2 di 2
    • Loosen the 8 Philips screws on the bottom of the laptop. They will not come all the way out but loosen till they spin freely.
    • Use a splurger to slowly pry the bottom cover off the laptop. Pull the bottom off in the direction of the arrow.
    • Important Be carefull to not break the snaps as they are delicate.
  2. Dell Latitude E5470 Screen Assembly  Replacement, Disconnect Battery: passo 2, immagine 1 di 1
    • Important Disconnect the battery before any work is done. Failure to do so could result in electric shock and cause harm to you and the laptop.
    • Carefully use the plastic tab to remove the battery cable from the motherboard.
  3. Dell Latitude E5470 Screen Assembly  Replacement, Disconnect Wireless Card: passo 3, immagine 1 di 2 Dell Latitude E5470 Screen Assembly  Replacement, Disconnect Wireless Card: passo 3, immagine 2 di 2
    • Unscrew the screw holding the card in place.
    • Remove the metal guard holding the connections in place.
    • Use the splurger to gently lift the wires from the card.
  4. Dell Latitude E5470 Screen Assembly  Replacement, Disconnect Display: passo 4, immagine 1 di 2 Dell Latitude E5470 Screen Assembly  Replacement, Disconnect Display: passo 4, immagine 2 di 2
    • Remove screw holding the metal plate in place.
    • Remove metal plate
    • Carefully pull on the tab to disconnect the display cable from the motherboard.
  5. Dell Latitude E5470 Screen Assembly  Replacement, Free display cables: passo 5, immagine 1 di 2 Dell Latitude E5470 Screen Assembly  Replacement, Free display cables: passo 5, immagine 2 di 2
    • Remove both screws holding the plate in place.
    • Remove plate
    • Remove tape holding the display cable to the laptop.
    • Pull the cable free
  6. Dell Latitude E5470 Screen Assembly  Replacement, Remove hinge covers: passo 6, immagine 1 di 2 Dell Latitude E5470 Screen Assembly  Replacement, Remove hinge covers: passo 6, immagine 2 di 2
    • Remove both the screws and hing covers on the back of the device.
  7. Dell Latitude E5470 Screen Assembly  Replacement, Remove display screws - Part 1: passo 7, immagine 1 di 2 Dell Latitude E5470 Screen Assembly  Replacement, Remove display screws - Part 1: passo 7, immagine 2 di 2
    • Remove two screws from the bottom of the device
  8. Dell Latitude E5470 Screen Assembly  Replacement, Remove display screws - Part 2: passo 8, immagine 1 di 2 Dell Latitude E5470 Screen Assembly  Replacement, Remove display screws - Part 2: passo 8, immagine 2 di 2
    • Remove screws underneath the hinge covers on the back of the device
  9. Dell Latitude E5470 Screen Assembly  Replacement, Remove display: passo 9, immagine 1 di 1
    • Carefully remove the display from its slots.
    • Be mindful to feed the WiFi and Display cables through the holes.
  10. Dell Latitude E5470 Screen Assembly  Replacement, You are done!: passo 10, immagine 1 di 1
    • The display is now disconnected from the laptop.
Conclusione
Altre 5 persone hanno completato questa guida.
Ethan Jones
Membro da: 07/16/18
542 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 24
Tutti i Tempi: 2,910
