Salta al contenuto principale
Dell Latitude E5470 Battery Replacement
Cosa ti serve
  1. Dell Latitude E5470 Battery Replacement, Removing the Battery: passo 1, immagine 1 di 1
    • Disconnect the battery cable from the connector on the system board [1].
    • Remove the screws that secure the battery to the computer [2].
    • Lift the battery away from the computer [3].
  2. Dell Latitude E5470 Battery Replacement, Remove the cable from the battery: passo 2, immagine 1 di 1
    • Unroute the cable from the routing channel [1] and remove the cable from the battery [2].
    • Connect the battery cable to the connector on the battery.
    • Route the battery cable through the routing channel on the battery
    • Insert the battery into the slot on the computer.
    • Tighten the screws to secure the battery to the computer.
    • Connect the battery cable to the connector on the system board
Conclusione
Marvin Romero
Membro da: 03/18/21
3.912 Reputazione
30 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
43 Membri
1.991 Guide realizzate
2Commenti sulla guida
I have this model but the problem is my battery. No batteries are currently installed. It seems that the battery cable for Latitude E5470 is faulty. How to confirm it's the cable?
Moutech - Replica
Same Here, Looks like the bios is Not accepting a non Dell battery. Any options to go round this Problem?
Peter Leest - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 64
Tutti i Tempi: 1,602
