Salta al contenuto principale
Dell Latitude E5430 Hard Drive Replacement
Cosa ti serve
  1. Dell Latitude E5430 Hard Drive Replacement, Remove the Battery: passo 1, immagine 1 di 1
    • Slide the two notches outward. Lift the battery outward and pull.
  2. Dell Latitude E5430 Hard Drive Replacement, Remove the Bottom Cover: passo 2, immagine 1 di 1
    • Remove two Phillips head screws from the bottom cover.
  3. Dell Latitude E5430 Hard Drive Replacement, Remove the Hard Drive Caddy: passo 3, immagine 1 di 1
    • Remove the four Phillips head screws from the hard drive caddy.
    • System memory (RAM) is located here.
    • Low profile WLAN card
    • Various components can be replaced from this stage.
  4. Dell Latitude E5430 Hard Drive Replacement, Unscrew the Hard Drive from the Caddy: passo 4, immagine 1 di 1
    • Remove the four Phillips head screws surrounding the hard drive in the caddy.
    • There are two more screws on the other side of the hard drive.
  5. Dell Latitude E5430 Hard Drive Replacement, Done!: passo 5, immagine 1 di 1
    • Congratulations, you've done it!
Conclusione
After you have installed your new hard drive or SSD, repeat the process in reverse.
Altre 5 persone hanno completato questa guida.
Sam
Membro da: 02/24/17
648 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 33
Tutti i Tempi: 3,612
