Salta al contenuto principale
Dell Latitude E5410 keyboard Replacement
Cosa ti serve
  1. Dell Latitude E5410 keyboard Replacement, Dell Latitude E5410 keyboard: passo 1, immagine 1 di 1
    • Position laptop so that the LCD screen is aligned directly flat and parallel to the keyboard section of the laptop.
  2. Dell Latitude E5410 keyboard Replacement: passo 2, immagine 1 di 1
    • Use the iFix it Opening Tool to remove the flat section located directly above the keyboard, as seen in picture.
  3. Dell Latitude E5410 keyboard Replacement: passo 3, immagine 1 di 1
    • Locate two internal screws (pictured) under removed section.
    • Use the Phillips screwdriver to remove both screws.
    • The screw in the middle is 3.85mm and the screw on the left is 8.66mm.
  4. Dell Latitude E5410 keyboard Replacement: passo 4, immagine 1 di 1
    • Firmly grip the upper section of the keyboard.
    • Pull on the keyboard in an upwards motion.
    • The keyboard should be successfully removed.
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
thanks man but its super easy not moderat i have 16 years old and i remove my keybord...
ZendomXGamer ZXG - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 5,104
