Salta al contenuto principale
Dell Latitude E4310 Display Replacement
Cosa ti serve
  1. Dell Latitude E4310 Display Replacement, Battery: passo 1, immagine 1 di 1
    • Power down the laptop and remove all power cords.
  2. Dell Latitude E4310 Display Replacement: passo 2, immagine 1 di 2 Dell Latitude E4310 Display Replacement: passo 2, immagine 2 di 2
    • Push in the battery release button with your thumb.
    • Pull up on the battery to remove.
  3. Dell Latitude E4310 Display Replacement, Display: passo 3, immagine 1 di 3 Dell Latitude E4310 Display Replacement, Display: passo 3, immagine 2 di 3 Dell Latitude E4310 Display Replacement, Display: passo 3, immagine 3 di 3
    • Open up the laptop and flatten it down on a workable surface.
    • Turn it around so that the screen is closest to you.
    • Insert the flat end of a spudger, or plastic opening tool, into the groove between the screen bezel and top case.
    • Twist the spudger, or plastic opening tool, until you hear a clicking sound and continue doing this around the entirety of the display.
    • Remove the bezel.
  4. Dell Latitude E4310 Display Replacement: passo 4, immagine 1 di 2 Dell Latitude E4310 Display Replacement: passo 4, immagine 2 di 2
    • Remove the six 0.3mm Phillips #1 screws.
  5. Dell Latitude E4310 Display Replacement: passo 5, immagine 1 di 2 Dell Latitude E4310 Display Replacement: passo 5, immagine 2 di 2
    • Remove the two 0.5mm Phillips #1 screws.
    • There are two screws located at each corner. Only remove the ones closest to the outer edge.
  6. Dell Latitude E4310 Display Replacement: passo 6, immagine 1 di 2 Dell Latitude E4310 Display Replacement: passo 6, immagine 2 di 2
    • Carefully lift the screen up and flip it over onto the keyboard side as if you were turning the page of a book.
  7. Dell Latitude E4310 Display Replacement: passo 7, immagine 1 di 3 Dell Latitude E4310 Display Replacement: passo 7, immagine 2 di 3 Dell Latitude E4310 Display Replacement: passo 7, immagine 3 di 3
    • Use a pair of tweezers to flip the blue tape 180 degrees.
    • By flipping the tape you disconnect the display connector.
  8. Dell Latitude E4310 Display Replacement: passo 8, immagine 1 di 1
    • Remove the screen from the laptop.
Conclusione
Altre 5 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,493
