Salta al contenuto principale
Dell Latitude E4300 Keyboard Replacement
Cosa ti serve
  1. Dell Latitude E4300 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Open the laptop and remove the small panel located above the keyboard.
  2. Dell Latitude E4300 Keyboard Replacement: passo 2, immagine 1 di 1
    • Using a Phillips 1 Screwdriver, unscrew the three M2x3-mm screws located above the keyboard where the small panel was originally.
  3. Dell Latitude E4300 Keyboard Replacement: passo 3, immagine 1 di 1
    • Pull off keyboard forward and then outwards.
    • The keyboard is fragile, so make sure you pull the keyboard off carefully.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 677
