Salta al contenuto principale
Dell Latitude E4200 SSD Replacement
Cosa ti serve
  1. Dell Latitude E4200 SSD Replacement, Back Panel: passo 1, immagine 1 di 1
    • Use PH0 screwdriver to unscrew the 4.49x7.88 mm screw in the middle of the back panel.
  2. Dell Latitude E4200 SSD Replacement: passo 2, immagine 1 di 3 Dell Latitude E4200 SSD Replacement: passo 2, immagine 2 di 3 Dell Latitude E4200 SSD Replacement: passo 2, immagine 3 di 3
    • Place thumbs flat on the front side of the back panel (the side to open the laptop).
    • Push panel upwards sliding it out of the locked position.
    • Lift panel out of socket.
  3. Dell Latitude E4200 SSD Replacement: passo 3, immagine 1 di 1
    • Remove panel and screw from the device. This opens up the main board of the device.
  4. Dell Latitude E4200 SSD Replacement, SSD: passo 4, immagine 1 di 1
    • Unscrew the two 4.10x4.05 mm screws holding the SSD in place.
  5. Dell Latitude E4200 SSD Replacement: passo 5, immagine 1 di 1
    • Using your finger and thumb lift the hard drive out of the computer but do not disconnect the attached connector to the computer.
  6. Dell Latitude E4200 SSD Replacement: passo 6, immagine 1 di 1
    • By applying pressure to the sides of the connector, pull the connector apart from the SSD.
Conclusione
Altre 6 persone hanno completato questa guida.
Baylor, Team 5-6, Williams Spring 2015 Membro di Baylor, Team 5-6, Williams Spring 2015
BU-WILLIAMS-S15S5G6
4 Membri
6 Guide realizzate
Un commento
You can use any mSATA SSD as replacement by using the following caddy/adapter:
https://www.ebay.fr/itm/166263029472
jacques_06 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 34
Tutti i Tempi: 8,402
