Salta al contenuto principale
Dell Latitude E4200 RAM Replacement
Cosa ti serve
  1. Dell Latitude E4200 RAM Replacement, Back Panel: passo 1, immagine 1 di 1
    • Use PH0 screwdriver to unscrew the 4.49x7.88 mm screw in the middle of the back panel.
  2. Dell Latitude E4200 RAM Replacement: passo 2, immagine 1 di 3 Dell Latitude E4200 RAM Replacement: passo 2, immagine 2 di 3 Dell Latitude E4200 RAM Replacement: passo 2, immagine 3 di 3
    • Place thumbs flat on the front side of the back panel (the side to open the laptop).
    • Push panel upwards sliding it out of the locked position.
    • Lift panel out of socket.
  3. Dell Latitude E4200 RAM Replacement: passo 3, immagine 1 di 1
    • Remove panel and screw from the device. This opens up the main board of the device.
  4. Dell Latitude E4200 RAM Replacement, Remove the back panel: passo 4, immagine 1 di 1
    • Once you removed the back panel, the RAM will easily be located.
    • Be sure to remove the battery first
  5. Dell Latitude E4200 RAM Replacement, Take out the RAM: passo 5, immagine 1 di 2 Dell Latitude E4200 RAM Replacement, Take out the RAM: passo 5, immagine 2 di 2
    • Place your thumbs on each side of the RAM tabs.
    • Gently push outward on the tabs to release the RAM. This will allow you to remove the RAM completely from your device.
    • The RAM should "bump up" after you push away the tabs.
  6. Dell Latitude E4200 RAM Replacement: passo 6, immagine 1 di 3 Dell Latitude E4200 RAM Replacement: passo 6, immagine 2 di 3 Dell Latitude E4200 RAM Replacement: passo 6, immagine 3 di 3
    • Gently grab each side of the RAM and remove it from the device.
    • Please do not touch connection side of the RAM (shown in orange) with fingers. It might causes possible corrosion to the connection.
Conclusione
Altre 2 persone hanno completato questa guida.
Chao Wei
Membro da: 03/22/15
146 Reputazione
1 Guida realizzata
Baylor, Team 5-6, Williams Spring 2015 Membro di Baylor, Team 5-6, Williams Spring 2015
BU-WILLIAMS-S15S5G6
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 2,649
