Salta al contenuto principale
Dell Latitude E4200 Keyboard Replacement
Cosa ti serve
  1. Dell Latitude E4200 Keyboard Replacement, Power Button Panel: passo 1, immagine 1 di 1
    • Open computer.
  2. Dell Latitude E4200 Keyboard Replacement: passo 2, immagine 1 di 1
    • Slide any tool with a flat surface under the side bottom right corner of front panel and pry the front panel out of place.
    • A small flat head screwdriver would be an ideal tool to use during this step.
  3. Dell Latitude E4200 Keyboard Replacement: passo 3, immagine 1 di 1
    • Once out of place, position your thumbs under the bottom of the panel and pull upwards.
  4. Dell Latitude E4200 Keyboard Replacement, Keyboard: passo 4, immagine 1 di 1
    • Use a PH00 screwdriver to unscrew the screw.
  5. Dell Latitude E4200 Keyboard Replacement: passo 5, immagine 1 di 2 Dell Latitude E4200 Keyboard Replacement: passo 5, immagine 2 di 2
    • Use your hands to gently lift the keyboard from the device.
  6. Dell Latitude E4200 Keyboard Replacement: passo 6, immagine 1 di 1
    • Gently turn the keyboard over.
  7. Dell Latitude E4200 Keyboard Replacement: passo 7, immagine 1 di 1
    • Be careful not to disconnect the keyboard connector.
  8. Dell Latitude E4200 Keyboard Replacement: passo 8, immagine 1 di 1
    • Use a flat head screwdriver to flip the keyboard connector up. This will allow you to disconnect the keyboard and remove it.
  9. Dell Latitude E4200 Keyboard Replacement: passo 9, immagine 1 di 1
    • Completely lift the keyboard from the device, as they are now disassembled.
Conclusione
Altre 3 persone hanno completato questa guida.
Baylor, Team 5-6, Williams Spring 2015 Membro di Baylor, Team 5-6, Williams Spring 2015
BU-WILLIAMS-S15S5G6
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 4,297
