Salta al contenuto principale
Dell Latitude D820 Hard Drive Replacement
Cosa ti serve
  1. Dell Latitude D820 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the charger from the laptop.
    • Turn the laptop over and locate the battery slide lock. Slide the switch and gently lift up the battery.
    • If you are replacing other components, leave the battery out.
    • If you are only replacing the battery, reverse the steps to install a new battery.
  2. Dell Latitude D820 Hard Drive Replacement, Hard Drive: passo 2, immagine 1 di 2 Dell Latitude D820 Hard Drive Replacement, Hard Drive: passo 2, immagine 2 di 2
    • Locate the hard drive compartment in the lower right hand corner of the bottom of the laptop. It is located next to the empty battery compartment. The words 'Strike Zone' are engraved on it.
    • Locate and remove three philips head screws. These screws measure 3.55mm in length and 2.93mm in width with a fine thread.
    • Gently slide grip pad to the right and the hard drive should slide out.
    • Reverse the process to install new hard drive.
Conclusione
Removing and replacing the hard drive
Altre 2 persone hanno completato questa guida.
Elizabeth
Membro da: 09/06/14
423 Reputazione
2 Guide realizzate
Pasco Hernando, Team 1-2, Prince Fall 2014 Membro di Pasco Hernando, Team 1-2, Prince Fall 2014
PHSC-PRINCE-F14S1G2
10 Membri
7 Guide realizzate
Un commento
You also need to unscrew the grip pad from the old hd and screw it onto the new one.
Sue - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 38
Tutti i Tempi: 3,647
