Salta al contenuto principale
Dell Latitude D630 RAM (Slot B) Replacement
Cosa ti serve
  1. Dell Latitude D630 RAM (Slot B) Replacement, Battery: passo 1, immagine 1 di 1
    • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Turn the laptop over so its bottom is facing you.
    • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
  2. Dell Latitude D630 RAM (Slot B) Replacement: passo 2, immagine 1 di 1
    • Using two index fingers, slide the battery latches outward.
    • While still holding the latches out, use your thumbs to slide the battery out towards you.
    • Once the battery is dislodged, you can let go of the latches and remove the battery.
  3. Dell Latitude D630 RAM (Slot B) Replacement, RAM (Slot B): passo 3, immagine 1 di 1
    • Locate and unscrew the captive screw indicated in the picture on the left to detach the panel.
  4. Dell Latitude D630 RAM (Slot B) Replacement: passo 4, immagine 1 di 1
    • Use your fingers to push out the latches holding the RAM in place.
    • The RAM should now sit up at an angle so you can safely remove it.
Conclusione
To install the new RAM, set it in the slot at an angle and push it in until the latches reclick.
Altre 14 persone hanno completato questa guida.
Jon Amireh
Membro da: 01/17/13
1.696 Reputazione
8 Guide realizzate
Cal Poly, Team 6-1, Johann Winter 2013 Membro di Cal Poly, Team 6-1, Johann Winter 2013
CPSU-JOHANN-W13S6G1
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 23
Tutti i Tempi: 5,959
