Introduzione
Introduction
Ram is your laptops temporary memory and can be replaced if damaged or you can upgrade it. This will help run more programs or make the ones you run faster and more efficient.
This Guide Will Teach You
  1. Where the ram is located
  2. How to remove safely
  3. Tools needed to complete the replacement
Parti
Nessuna parte richiesta.
Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
  • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
  • Turn the laptop over so its bottom is facing you.
  • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
Aggiungi Commento
Using two index fingers, slide the battery latches outward.
  • Using two index fingers, slide the battery latches outward.
  • While still holding the latches out, use your thumbs to slide the battery out towards you.
  • Once the battery is dislodged, you can let go of the latches and remove the battery.
Aggiungi Commento
  • Locate and unscrew the captive screw indicated in the picture on the left to detach the panel.
Aggiungi Commento
  • Use your fingers to push out the latches holding the RAM in place.
  • The RAM should now sit up at an angle so you can safely remove it.
Aggiungi Commento
Conclusione
To install the new RAM, set it in the slot at an angle and push it in until the latches reclick.
Altre 11 persone hanno completato questa guida.
Jon Amireh
Membro da: 17/01/2013
1.370 Reputazione
8 Guide realizzate
Cal Poly, Team 6-1, Johann Winter 2013 Membro di Cal Poly, Team 6-1, Johann Winter 2013
CPSU-JOHANN-W13S6G1
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 25
Tutti i Tempi: 4,772
