Introduzione
Introduction
The hard drive is where you store permanent files on your laptop. If your hard drive is damaged and does not operate properly any more, or you simply want a larger and/or faster one, you can replace it with a new one.
This guide will teach you
  1. Where the Hard Drive is located
  2. how to remove safely
  3. Tools needed to complete the replacement
Parti
Nessuna parte specificata.
  1. Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Turn the laptop over so its bottom is facing you.
    • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
  2. Using two index fingers, slide the battery latches outward.
    • Using two index fingers, slide the battery latches outward.
    • While still holding the latches out, use your thumbs to slide the battery out towards you.
    • Once the battery is dislodged, you can let go of the latches and remove the battery.
  3. Kit di riparazione per Android
    Un nuovo schermo o una nuova batteria sono ad un kit di distanza.
    Acquista ora
    Acquista ora
  4. Position the closed laptop upside down. Unscrew the screw closest to the hard drive opening and the one diagonally to the right. This will loosen the hard drive. Do not unscrew this screw!
    • Position the closed laptop upside down.
    • Unscrew the screw closest to the hard drive opening and the one diagonally to the right. This will loosen the hard drive.
    • Do not unscrew this screw!
  5. Place thumb on the hard drive cover and get a firm grip.
    • Place thumb on the hard drive cover and get a firm grip.
    • Pull the hard drive out slowly to avoid any further damage to the laptop.
  6. Unscrew the screw on the right side to remove cover. Slide cover off.
    • Unscrew the screw on the right side to remove cover.
    • Slide cover off.
Conclusione
Altre 12 persone hanno completato questa guida.
Savi Chavan
Membro da: 12/03/2014
803 Reputation
1 Guida realizzata
Dell latitude 2RHczd1
C Chandler - Replica
Thank You Sir !
Bartłomiej Be - Replica
I appreciate the guide my good sir. Very helpful.
Matt Erti - Replica
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 55
All Time: 12,653
