Salta al contenuto principale
Dell Latitude D630 Hard Drive Replacement
Cosa ti serve
  1. Dell Latitude D630 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Turn the laptop over so its bottom is facing you.
    • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
  2. Dell Latitude D630 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Using two index fingers, slide the battery latches outward.
    • While still holding the latches out, use your thumbs to slide the battery out towards you.
    • Once the battery is dislodged, you can let go of the latches and remove the battery.
  3. Dell Latitude D630 Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 3 Dell Latitude D630 Hard Drive Replacement, Hard Drive: passo 3, immagine 2 di 3 Dell Latitude D630 Hard Drive Replacement, Hard Drive: passo 3, immagine 3 di 3
    • Position the closed laptop upside down.
    • Unscrew the screw closest to the hard drive opening and the one diagonally to the right. This will loosen the hard drive.
    • Do not unscrew this screw!
  4. Dell Latitude D630 Hard Drive Replacement: passo 4, immagine 1 di 1
    • Place thumb on the hard drive cover and get a firm grip.
    • Pull the hard drive out slowly to avoid any further damage to the laptop.
  5. Dell Latitude D630 Hard Drive Replacement: passo 5, immagine 1 di 2 Dell Latitude D630 Hard Drive Replacement: passo 5, immagine 2 di 2
    • Unscrew the screw on the right side to remove cover.
    • Slide cover off.
Conclusione
Altre 17 persone hanno completato questa guida.
Savi Chavan
Membro da: 03/12/14
979 Reputazione
1 Guida realizzata
4 Commenti
Dell latitude 2RHczd1
C Chandler - Replica
I appreciate the guide my good sir. Very helpful.
Matt Erti - Replica
Is the hard drive replaceable to 2.5-inch SSD? for example Kingston a400.
Aduh - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 28
Tutti i Tempi: 15,325
