Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
The purpose of the coin cell battery is to keep the date, time and other information in memory while the laptop’s main power is off. If your Dell Latitude D630 doesn't retain the correct time after resetting the clock, use this guide to replace the CMOS battery.
Parti
Nessuna parte specificata.
  1. Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Turn the laptop over so its bottom is facing you.
    • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
  2. Using two index fingers, slide the battery latches outward.
    • Using two index fingers, slide the battery latches outward.
    • While still holding the latches out, use your thumbs to slide the battery out towards you.
    • Once the battery is dislodged, you can let go of the latches and remove the battery.
  3. With the battery removed, turn the laptop face up and open the lid a complete 180 degrees. Using a plastic opening tool, pry off the corner of the keyboard bezel by undoing the tab. Once you've removed the corner of the bezel, you can use your hands to slowly, but with moderate force, pull the rest of the bezel slightly up and towards you to release the remaining tabs.
    • With the battery removed, turn the laptop face up and open the lid a complete 180 degrees.
    • Using a plastic opening tool, pry off the corner of the keyboard bezel by undoing the tab.
    • Once you've removed the corner of the bezel, you can use your hands to slowly, but with moderate force, pull the rest of the bezel slightly up and towards you to release the remaining tabs.
  4. Remove the three 3mm Phillips #0 screws securing the keyboard.
    • Remove the three 3mm Phillips #0 screws securing the keyboard.
  5. Slowly bring the keyboard up and fold it back onto the touchpad. Be careful not to pull too hard or too far when folding over the keyboard. The keyboard is still connected to the motherboard by a short ribbon cable.
    • Slowly bring the keyboard up and fold it back onto the touchpad.
    • Be careful not to pull too hard or too far when folding over the keyboard. The keyboard is still connected to the motherboard by a short ribbon cable.
  6. Use a plastic opening tool to unhook the blue latch that secures the keyboard cable. Using the blue tab, pull the keyboard cable connector from its socket on the motherboard.
    • Use a plastic opening tool to unhook the blue latch that secures the keyboard cable.
    • Using the blue tab, pull the keyboard cable connector from its socket on the motherboard.
  7. Remove the connector to the coin using the spudger.
    • Remove the connector to the coin using the spudger.
    • Slide the coin battery out of its slot by wiggling its connector with a gentle tug.
    • You may also need to use the spudger to carefully push out the battery from the top of the slot where the yellow square is.
Conclusione
Altre 26 persone hanno completato questa guida.
Jon Amireh
Membro da: 17/01/2013
1.457 Reputazione
8 Guide realizzate
Cal Poly, Team 6-1, Johann Winter 2013 Membro di Cal Poly, Team 6-1, Johann Winter 2013
CPSU-JOHANN-W13S6G1
4 Membri
9 Guide realizzate
off topic but...in step 4, what is the component plugged into the white cable at the top left hand corner right above that screw?
Josh Henderson - Replica
That looks like the Bluetooth module @Josh Henderson
stm reusables -
I love the easy-to-fix design of these older Dell Latitudes!
Joseph Sctbunio - Replica
Worst CMOS battery placement I have seen. PPD
Lewis Balentine - Replica
it is proving a lot harder to get the battery back in place than to remove it. More photos and guidence would be a helpful.
chefkevin1uk - Replica
One question. Since the battery is nowhere near the keyboard cable, could you just prop the keyboard up so it’s out of your way and then replace the battery? Also, how is the black plastic surrounding the battery connected to the laptop? Would it make it easier to replace if you removed that first?
Patrick Dickey - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 45
Ultimi 30 Giorni: 280
Tutti i Tempi: 39,847
