Introduzione
Use this guide to replace the battery in your Dell Latitude D630 or to remove it before performing other repairs.
Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
Turn the laptop over so its bottom is facing you.
To install your new battery, follow the steps in reverse order and slide your new battery in.
Altre 12 persone hanno completato questa guida.
