Introduzione
Guide to installing new RAM modules for the Dell Latitude D620.
Cosa ti serve
With the keyboard removed, you should be able to see ram slot A.
Place new ram into the slot making sure it is aligned
Altre 23 persone hanno completato questa guida.
2 Commenti
If you are increasing the amount of RAM installed -> On first power on after installing the RAM, system on boot up will complain about memory size changed, and to reseat the memory. Wait for about 60 - 90 seconds, and you will receive a few additional messages about F1 to continue or F2 for Setup. Go into Setup and verify that the system sees all memory installed. If installing 2 x 2GB DDR2, max possible, 4GB. BIOS setup should report 4GB installed, of which 3.37GB usable.
J’étais inquiet, mais en lisant votre commentaire, me voilà rassuré et j’ai donc suivi vos instructions. Ca fonctionne 2X2 GO …Merci
Please help me
manaqib arif - Replica
Mera display ka masla hai
