Salta al contenuto principale
Dell Latitude D620 CD Drive Replacement
Cosa ti serve
  1. Dell Latitude D620 CD Drive Replacement, Keyboard: passo 1, immagine 1 di 1
    • Power down the laptop and remove the battery.
    • Open the laptop cover all of the way.
  2. Dell Latitude D620 CD Drive Replacement: passo 2, immagine 1 di 3 Dell Latitude D620 CD Drive Replacement: passo 2, immagine 2 di 3 Dell Latitude D620 CD Drive Replacement: passo 2, immagine 3 di 3
    • Locate the notch under the cover at the top of the keyboard
    • Using the spudger as a lever, lift the plastic covering
    • Carefully remove the rest of the covering from right to left
  3. Dell Latitude D620 CD Drive Replacement: passo 3, immagine 1 di 1
    • Unscrew the top portion of the keyboard using a #00 screwdriver
  4. Dell Latitude D620 CD Drive Replacement: passo 4, immagine 1 di 1
    • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
    • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
  5. Dell Latitude D620 CD Drive Replacement: passo 5, immagine 1 di 2 Dell Latitude D620 CD Drive Replacement: passo 5, immagine 2 di 2
    • Once keyboard is out of the case, lay it face-down on the track pad
  6. Dell Latitude D620 CD Drive Replacement: passo 6, immagine 1 di 2 Dell Latitude D620 CD Drive Replacement: passo 6, immagine 2 di 2
    • Using a small spudger, pull back on the black bar to release the blue lever
  7. Dell Latitude D620 CD Drive Replacement: passo 7, immagine 1 di 1
    • Pull up on the metal bar connected to the socket to detach the ribbon cable
  8. Dell Latitude D620 CD Drive Replacement, CD Drive: passo 8, immagine 1 di 2 Dell Latitude D620 CD Drive Replacement, CD Drive: passo 8, immagine 2 di 2
    • Press in the tab on the bottom right side of the CD drive
    • The tab comes out on its own; there is no need to pull it out manually.
  9. Dell Latitude D620 CD Drive Replacement: passo 9, immagine 1 di 1
    • Gently pull the tab to remove the disk tray.
Conclusione
Altre 10 persone hanno completato questa guida.
Ivan
Membro da: 04/15/10
194 Reputazione
1 Guida realizzata
Cal Poly, Team 24-35, Regan Spring 2010 Membro di Cal Poly, Team 24-35, Regan Spring 2010
CPSU-REGAN-S10S24G35
4 Membri
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 29
Tutti i Tempi: 8,464
