Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Replacing a defective modem is fairly simple and will help your computer in connecting to networks requiring a modem.
Parti
Nessuna parte specificata.
  1. Remove the 3.9 mm Phillips #1 screw from the battery compartment. Remove the 3.9 mm Phillips #1 screw from the battery compartment.
    • Remove the 3.9 mm Phillips #1 screw from the battery compartment.
  2. Locate the laptop battery release button lock Push the battery release in the direction of the arrow, and pull upward. Push the battery release in the direction of the arrow, and pull upward.
    • Locate the laptop battery release button lock
    • Push the battery release in the direction of the arrow, and pull upward.
  3. Remove the battery from its compartment.
    • Remove the battery from its compartment.
  4. APRI TUTTE LE SCHEDE
    Kit espansione RAM per Mac
    Acquista Kit
    Abbastanza RAM
    Per tutte le schede
    Acquista Kit
  5. Remove the 3.9mm screw with a Philips #1 screwdriver containing the modem. Remove the 3.9mm screw with a Philips #1 screwdriver containing the modem. Remove the 3.9mm screw with a Philips #1 screwdriver containing the modem.
    • Remove the 3.9mm screw with a Philips #1 screwdriver containing the modem.
  6. Lift and remove the lid. Lift and remove the lid.
    • Lift and remove the lid.
  7. Remove the 3.9mm Philips #1 screw on top of the modem. Remove the 3.9mm Philips #1 screw on top of the modem.
    • Remove the 3.9mm Philips #1 screw on top of the modem.
  8. Pull on the white tab to remove the modem Remove the cable going to the modem. Remove the cable going to the modem.
    • Pull on the white tab to remove the modem
    • Remove the cable going to the modem.
Conclusione
Jose Chavez
Membro da: 26/01/2014
113 Reputazione
1 Guida realizzata
Cal Poly, Team 6-24, Maness Winter 2014 Membro di Cal Poly, Team 6-24, Maness Winter 2014
CPSU-MANESS-W14S6G24
4 Membri
5 Guide realizzate
I have manufacturing mode problem can you help me??
Mod - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,366
