Salta al contenuto principale
Dell Latitude D600 Wireless WiFi Card Replacement
Cosa ti serve
  1. Dell Latitude D600 Wireless WiFi Card Replacement, Battery: passo 1, immagine 1 di 1
    • Find the battery
  2. Dell Latitude D600 Wireless WiFi Card Replacement: passo 2, immagine 1 di 2 Dell Latitude D600 Wireless WiFi Card Replacement: passo 2, immagine 2 di 2
    • Pull the tab to release the battery
  3. Dell Latitude D600 Wireless WiFi Card Replacement: passo 3, immagine 1 di 1
    • Pull the battery out
  4. Dell Latitude D600 Wireless WiFi Card Replacement, Wireless WiFi Card: passo 4, immagine 1 di 1
    • Use your screwdriver to unscrew and lift up the panel on the right labeled with a C
  5. Dell Latitude D600 Wireless WiFi Card Replacement: passo 5, immagine 1 di 1
    • Pull off the two wires connected to the wireless card
    • They should come off fairly easy
  6. Dell Latitude D600 Wireless WiFi Card Replacement: passo 6, immagine 1 di 2 Dell Latitude D600 Wireless WiFi Card Replacement: passo 6, immagine 2 di 2
    • Pull the two tabs away from the card and pull up on the intel card
    • Then pull it away from the holding slot to remove it
  7. Dell Latitude D600 Wireless WiFi Card Replacement: passo 7, immagine 1 di 2 Dell Latitude D600 Wireless WiFi Card Replacement: passo 7, immagine 2 di 2
    • When placing in your new wireless card, connect the two wires before inserting into the slot
    • Then line it up, put the card in at an angle and push down so the side tabs lock it into place
Conclusione
Altre 6 persone hanno completato questa guida.
Joseph
Membro da: 07/16/14
1.497 Reputazione
5 Guide realizzate
Un commento
Hi,
dell latitude D600 Laptop
Can you please help me, I cant release my wireless card, by pulling the tabs on cards sides.?
It just doesn't release the card to pull out, is there any other way I can remove my card.?
Email me if you can .
robert.wilson407@ntlworld.com
Thanking you Rob
rob wilson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 2,633
