Introduzione
This guide will show how to add RAM or replace existing RAM on the Latitude D600
Parti
Nessuna parte richiesta.
Find the battery
  • Find the battery
Aggiungi Commento
Pull the tab to release the battery
  • Pull the tab to release the battery
Aggiungi Commento
  • Pull the battery out
Aggiungi Commento
  • Find the panel underneath the microsoft product key sticker, the panel is labeled with an M
  • Unscrew the single screw above the M
Aggiungi Commento
  • Pull off the panel to reveal the RAM
  • RAM is held in by two tabs, pull each tab to the side and the RAM will pop up
Aggiungi Commento
  • Once the RAM is popped up, slowly pull it out of the slot
Aggiungi Commento
  • To add or replace RAM, place the memory into the slot at an angle
  • Make sure you line it up correctly
  • If it is in correctly it should stay up at an angle by itself
  • Then push down in the middle until it clicks into place
Aggiungi Commento
  • The RAM should be secured by the tabs where the two semi circles are on the RAM
  • If it is not secure, just gently pull it out and try again, use the images to help you out
Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Joseph
Membro da: 16/07/2014
1.427 Reputazione
6 Guide realizzate
Almost perfect: easy; clear;
Herman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 30
Tutti i Tempi: 1,797
