Salta al contenuto principale
Dell Latitude D600 RAM (Main Memory) Replacement
Cosa ti serve
  1. Dell Latitude D600 RAM (Main Memory) Replacement, Battery: passo 1, immagine 1 di 1
    • Find the battery
  2. Dell Latitude D600 RAM (Main Memory) Replacement: passo 2, immagine 1 di 2 Dell Latitude D600 RAM (Main Memory) Replacement: passo 2, immagine 2 di 2
    • Pull the tab to release the battery
  3. Dell Latitude D600 RAM (Main Memory) Replacement: passo 3, immagine 1 di 1
    • Pull the battery out
  4. Dell Latitude D600 RAM (Main Memory) Replacement, RAM (Main Memory): passo 4, immagine 1 di 2 Dell Latitude D600 RAM (Main Memory) Replacement, RAM (Main Memory): passo 4, immagine 2 di 2
    • Find the panel underneath the microsoft product key sticker, the panel is labeled with an M
    • Unscrew the single screw above the M
  5. Dell Latitude D600 RAM (Main Memory) Replacement: passo 5, immagine 1 di 3 Dell Latitude D600 RAM (Main Memory) Replacement: passo 5, immagine 2 di 3 Dell Latitude D600 RAM (Main Memory) Replacement: passo 5, immagine 3 di 3
    • Pull off the panel to reveal the RAM
    • RAM is held in by two tabs, pull each tab to the side and the RAM will pop up
  6. Dell Latitude D600 RAM (Main Memory) Replacement: passo 6, immagine 1 di 1
    • Once the RAM is popped up, slowly pull it out of the slot
  7. Dell Latitude D600 RAM (Main Memory) Replacement: passo 7, immagine 1 di 3 Dell Latitude D600 RAM (Main Memory) Replacement: passo 7, immagine 2 di 3 Dell Latitude D600 RAM (Main Memory) Replacement: passo 7, immagine 3 di 3
    • To add or replace RAM, place the memory into the slot at an angle
    • Make sure you line it up correctly
    • If it is in correctly it should stay up at an angle by itself
    • Then push down in the middle until it clicks into place
  8. Dell Latitude D600 RAM (Main Memory) Replacement: passo 8, immagine 1 di 1
    • The RAM should be secured by the tabs where the two semi circles are on the RAM
    • If it is not secure, just gently pull it out and try again, use the images to help you out
Conclusione
Altre 6 persone hanno completato questa guida.
Joseph
Membro da: 07/16/14
1.497 Reputazione
5 Guide realizzate
Un commento
Almost perfect: easy; clear;
Herman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,828
