Salta al contenuto principale
Introduzione
A CD-ROM Drive is a necessity when trying to use a CD or DVD on a laptop. It is important to know that if there is difficulty among the CD-ROM Drive and you would like to replace it , a screw driver would be handy. This repair guide would allow you to replace your CD-ROM Drive and successfully be able to use it.
Parti
Nessuna parte specificata.
  1. The CD ROM Drive is located on the right side of the laptop. Use the Phillips #1 to unscrew the 6mm lock screw. The screw is located underneath the CD-ROM Drive with a lock symbol on it. Use the Phillips #1 to unscrew the 6mm lock screw. The screw is located underneath the CD-ROM Drive with a lock symbol on it.
    • The CD ROM Drive is located on the right side of the laptop.
    • Use the Phillips #1 to unscrew the 6mm lock screw. The screw is located underneath the CD-ROM Drive with a lock symbol on it.
  2. Kit di riparazione batterie iPhone
    Solo $29.99
    Buy Now
    Solo $29.99
    Buy Now
  3. remove the CD ROM Drive: push the indicated button in towards the laptop and release.  The button will pop out. remove the CD ROM Drive: push the indicated button in towards the laptop and release.  The button will pop out. remove the CD ROM Drive: push the indicated button in towards the laptop and release.  The button will pop out.
    • remove the CD ROM Drive: push the indicated button in towards the laptop and release. The button will pop out.
  4. Remove the CD ROM Drive: Pull on the now released button and the CD ROM  Drive will come out. Remove the CD ROM Drive: Pull on the now released button and the CD ROM  Drive will come out.
    • Remove the CD ROM Drive: Pull on the now released button and the CD ROM Drive will come out.
Conclusione
Kyle Cabral
Membro da: 19/03/2018
510 Reputazione
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 98
