Salta al contenuto principale
Dell Latitude D430 Wireless Adapter Replacement
Cosa ti serve
  1. Dell Latitude D430 Wireless Adapter Replacement, Wireless Adapter: passo 1, immagine 1 di 3 Dell Latitude D430 Wireless Adapter Replacement, Wireless Adapter: passo 1, immagine 2 di 3 Dell Latitude D430 Wireless Adapter Replacement, Wireless Adapter: passo 1, immagine 3 di 3
    • Flip the laptop so you are able to see the bottom.
  2. Dell Latitude D430 Wireless Adapter Replacement: passo 2, immagine 1 di 2 Dell Latitude D430 Wireless Adapter Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the three screws that secure the small "L" shaped backplate.
  3. Dell Latitude D430 Wireless Adapter Replacement: passo 3, immagine 1 di 1
    • Once all 3 screws have been removed, carefully remove the panel by grabbing the edges, and pulling up.
  4. Dell Latitude D430 Wireless Adapter Replacement: passo 4, immagine 1 di 3 Dell Latitude D430 Wireless Adapter Replacement: passo 4, immagine 2 di 3 Dell Latitude D430 Wireless Adapter Replacement: passo 4, immagine 3 di 3
    • Identify the two pins connecting the wireless adapter to the motherboard. (The wireless adapter will say WLAN on it.)
    • Carefully pull up on each pin and remove them from the wireless adapter.
    • Note that there are no wires/cables connecting the wireless adapter to the motherboard.
  5. Dell Latitude D430 Wireless Adapter Replacement: passo 5, immagine 1 di 2 Dell Latitude D430 Wireless Adapter Replacement: passo 5, immagine 2 di 2
    • Pull back on the two metal tabs holding the wireless adapter down.
    • After the two metal tabs are pulled, the card will pop up.
  6. Dell Latitude D430 Wireless Adapter Replacement: passo 6, immagine 1 di 1
    • Pull the wireless adapter out away from where it was connected.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 511
