Salta al contenuto principale
Dell Latitude D430 Keyboard Replacement
Cosa ti serve
  1. Dell Latitude D430 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Lay the laptop flat with the screen facing upward. This will allow you to have the most room while performing the keyboard replacement.
  2. Dell Latitude D430 Keyboard Replacement: passo 2, immagine 1 di 2 Dell Latitude D430 Keyboard Replacement: passo 2, immagine 2 di 2
    • Identify the plastic cover located directly below the screen.
    • Carefully remove the plastic cover by lifting both ends of the cover.
    • This piece is very fragile, so be sure not to break this piece. It requires minimal force to remove this piece.
  3. Dell Latitude D430 Keyboard Replacement: passo 3, immagine 1 di 3 Dell Latitude D430 Keyboard Replacement: passo 3, immagine 2 di 3 Dell Latitude D430 Keyboard Replacement: passo 3, immagine 3 di 3
    • There are 3 screws that should be exposed now.
    • Use a Phillips 00 screwdriver to remove all 3 of the screws shown in the pictures.
  4. Dell Latitude D430 Keyboard Replacement: passo 4, immagine 1 di 3 Dell Latitude D430 Keyboard Replacement: passo 4, immagine 2 di 3 Dell Latitude D430 Keyboard Replacement: passo 4, immagine 3 di 3
    • Gently lift the keyboard from the top.
    • At the bottom of the keyboard, there will be ribbons connecting it to the motherboard. Be sure not to tear the ribbons.
    • Lift the clamps that are holding the ribbons in place in order to remove them. You should be able to remove the keyboard at this point.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 13
Tutti i Tempi: 419
