Salta al contenuto principale
Dell Latitude 9510 Speakers Replacement
Cosa ti serve
  1. Dell Latitude 9510 Speakers Replacement, Base Panel: passo 1, immagine 1 di 1
    • Flip the device so that the base plate is facing you.
    • Use a Phillips #0 screwdriver to remove the nine 5.5 mm screws securing the base plate.
  2. Dell Latitude 9510 Speakers Replacement: passo 2, immagine 1 di 1
    • Wedge a spudger between the base plate and the chassis, then gently pry around the entire perimeter to release the base plate.
    • Remove the base plate.
  3. Dell Latitude 9510 Speakers Replacement, Speakers: passo 3, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the four 2 mm screws from the speakers.
  4. Dell Latitude 9510 Speakers Replacement: passo 4, immagine 1 di 1
    • Use a spudger to gently lever the speaker connector out of its port.
    • Lift the speakers up and out.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 115
