Salta al contenuto principale
Dell Latitude 9510 Motherboard Replacement
Cosa ti serve
  1. Dell Latitude 9510 Motherboard Replacement, Base Panel: passo 1, immagine 1 di 1
    • Flip the device so that the base plate is facing you.
    • Use a Phillips #0 screwdriver to remove the nine 5.5 mm screws securing the base plate.
  2. Dell Latitude 9510 Motherboard Replacement: passo 2, immagine 1 di 1
    • Wedge a spudger between the base plate and the chassis, then gently pry around the entire perimeter to release the base plate.
    • Remove the base plate.
  3. Dell Latitude 9510 Motherboard Replacement, Speakers: passo 3, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the four 2 mm screws from the speakers.
  4. Dell Latitude 9510 Motherboard Replacement: passo 4, immagine 1 di 1
    • Use a spudger to gently lever the speaker connector out of its port.
    • Lift the speakers up and out.
  5. Dell Latitude 9510 Motherboard Replacement, Fan: passo 5, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the two 3 mm screws securing the fan.
  6. Dell Latitude 9510 Motherboard Replacement: passo 6, immagine 1 di 1
    • Place your fingernails behind the plastic tabs on the speaker's motherboard connector, then pull directly backwards, toward the wires, until the connector releases from its port.
    • Lift the fan up and out.
  7. Dell Latitude 9510 Motherboard Replacement, USB and Headphone Jack Replacement: passo 7, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the four 3.5 mm screws.
  8. Dell Latitude 9510 Motherboard Replacement: passo 8, immagine 1 di 1
    • Place your fingernails behind each of the plastic tabs on the plug, and pull directly backward until the connector releases.
  9. Dell Latitude 9510 Motherboard Replacement: passo 9, immagine 1 di 1
    • Flip up the locking bars on the two ZIF connectors so they stand vertically, then gently remove the two ribbon cables connected to the IO daughterboard.
    • Lift the IO daughterboard up and out.
  10. Dell Latitude 9510 Motherboard Replacement, Battery: passo 10, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the eight screws securing the battery.
  11. Dell Latitude 9510 Motherboard Replacement: passo 11, immagine 1 di 1
    • Place a spudger behind a plastic tab on either side of the plug, then "walk" the connector out of its socket by gently pushing the plug toward the cables, alternating sides, until the connector releases.
    • Lift the battery up and out.
  12. Dell Latitude 9510 Motherboard Replacement, Motherboard: passo 12, immagine 1 di 2 Dell Latitude 9510 Motherboard Replacement, Motherboard: passo 12, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the four screws.
    • Use a Phillips #00 screwdriver to remove the three screws.
  13. Dell Latitude 9510 Motherboard Replacement: passo 13, immagine 1 di 2 Dell Latitude 9510 Motherboard Replacement: passo 13, immagine 2 di 2
    • Flip up the small metal display cable clip, until the clip is parallel to the ribbon cable, then pull it directly backwards until it releases.
    • Flip up the lock-bar on the ZIF connector, then gently pull the ribbon cable until it releases.
    • This requires almost no force.
  14. Dell Latitude 9510 Motherboard Replacement: passo 14, immagine 1 di 2 Dell Latitude 9510 Motherboard Replacement: passo 14, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the seven 4.0 mm screws.
    • Use a Phillips #00 screwdriver to remove the two 4.5mm screws.
  15. Dell Latitude 9510 Motherboard Replacement: passo 15, immagine 1 di 1
    • Lift the motherboard up and out.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 19
Tutti i Tempi: 537
