Salta al contenuto principale
Dell Latitude 9510 Battery Replacement
Cosa ti serve
  1. Dell Latitude 9510 Battery Replacement, Base Panel: passo 1, immagine 1 di 1
    • Flip the device so that the base plate is facing you.
    • Use a Phillips #0 screwdriver to remove the nine 5.5 mm screws securing the base plate.
  2. Dell Latitude 9510 Battery Replacement: passo 2, immagine 1 di 1
    • Wedge a spudger between the base plate and the chassis, then gently pry around the entire perimeter to release the base plate.
    • Remove the base plate.
  3. Dell Latitude 9510 Battery Replacement, Battery: passo 3, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the eight screws securing the battery.
  4. Dell Latitude 9510 Battery Replacement: passo 4, immagine 1 di 1
    • Place a spudger behind a plastic tab on either side of the plug, then "walk" the connector out of its socket by gently pushing the plug toward the cables, alternating sides, until the connector releases.
    • Lift the battery up and out.
Conclusione
1Commento della guida
I have the Version with the 52 Wh battery.
Is it possible to upgrade my laptop to the 88 Wh battery?
Would appreciate any Insights on this!
Johann Mangelsen - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 43
Tutti i Tempi: 1,442
