Salta al contenuto principale
Dell Latitude 9410 2-in-1 Base Panel Replacement
Cosa ti serve
  1. Dell Latitude 9410 2-in-1 Base Panel Replacement, Base Panel: passo 1, immagine 1 di 1
    • Ensure that the laptop is unplugged and powered off before beginning.
    • Place the laptop upside down on a flat surface.
  2. Dell Latitude 9410 2-in-1 Base Panel Replacement: passo 2, immagine 1 di 2 Dell Latitude 9410 2-in-1 Base Panel Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #00 screwdriver to loosen the ten captive screws.
    • The screws are permanently fastened to the base panel; do not attempt to remove them.
  3. Dell Latitude 9410 2-in-1 Base Panel Replacement: passo 3, immagine 1 di 3 Dell Latitude 9410 2-in-1 Base Panel Replacement: passo 3, immagine 2 di 3 Dell Latitude 9410 2-in-1 Base Panel Replacement: passo 3, immagine 3 di 3
    • Carefully lift off the back panel.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 284
