Salta al contenuto principale
Dell Latitude 7420 Battery Replacement
Cosa ti serve
  1. Dell Latitude 7420 Battery Replacement, Battery: passo 1, immagine 1 di 2 Dell Latitude 7420 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the eight 7 mm screws from the from the back panel using the Phillips #1 screwdriver.
    • Please prevent the static damage by working from anti-static mat or wearing anti-static bracelet or touch the metal with hands to discharge.
  2. Dell Latitude 7420 Battery Replacement: passo 2, immagine 1 di 2 Dell Latitude 7420 Battery Replacement: passo 2, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Slide the opening pick in between the back cover and work your way around the edges to remove the back cover from the device.
    • Do not insert the pick tweezers too deep, since it may damage the other components on the motherboard.
  3. Dell Latitude 7420 Battery Replacement: passo 3, immagine 1 di 2 Dell Latitude 7420 Battery Replacement: passo 3, immagine 2 di 2
    • Using the Phillips #1 screwdriver, remove the five 5 mm screws.
  4. Dell Latitude 7420 Battery Replacement: passo 4, immagine 1 di 1
    • Disconnect the battery from the motherboard by gently pulling out the connector.
  5. Dell Latitude 7420 Battery Replacement: passo 5, immagine 1 di 2 Dell Latitude 7420 Battery Replacement: passo 5, immagine 2 di 2
    • Remove the battery from the laptop.
    • Before removing the battery from the laptop, please remove the cables that are attached on the battery.
Conclusione
Altre 4 persone hanno completato questa guida.
Hong Lee
Membro da: 05/11/21
208 Reputazione
1 Guida realizzata
Un commento
Do you know if you can upgrade the battery i.e. go from 42 to 63? I noticed the voltages were different.
Andrew Violet - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 88
Ultimi 30 Giorni: 372
Tutti i Tempi: 11,093
