Salta al contenuto principale
Dell Latitude 7390 SSD Replacement
Cosa ti serve
  1. Dell Latitude 7390 SSD Replacement, Bottom Panel: passo 1, immagine 1 di 1
    • Orient your Dell Latitude 7390 laptop so that it is facing towards you as if you're going to open it.
  2. Dell Latitude 7390 SSD Replacement: passo 2, immagine 1 di 3 Dell Latitude 7390 SSD Replacement: passo 2, immagine 2 di 3 Dell Latitude 7390 SSD Replacement: passo 2, immagine 3 di 3
    • Flip your laptop over so that the bottom is facing up.
  3. Dell Latitude 7390 SSD Replacement: passo 3, immagine 1 di 1
    • Using your Phillips #1 screwdriver, remove the eight 6 mm screws around the border of the bottom panel.
  4. Dell Latitude 7390 SSD Replacement: passo 4, immagine 1 di 2 Dell Latitude 7390 SSD Replacement: passo 4, immagine 2 di 2
    • Using an opening tool or picks, work your way around the periphery and pry the back case off.
  5. Dell Latitude 7390 SSD Replacement: passo 5, immagine 1 di 1
    • Finally, lift the back panel off to uncover the inside of your Dell Latitude 7390.
  6. Dell Latitude 7390 SSD Replacement, Battery: passo 6, immagine 1 di 1
    • Make sure the laptop is turned OFF and unplugged from the power adapter before taking the battery out.
    • Use the Phillips #1 screwdriver to remove the five 6 mm screws holding the battery in place along the edges of the battery.
  7. Dell Latitude 7390 SSD Replacement: passo 7, immagine 1 di 3 Dell Latitude 7390 SSD Replacement: passo 7, immagine 2 di 3 Dell Latitude 7390 SSD Replacement: passo 7, immagine 3 di 3
    • Be careful not to break the connector by pulling too hard on the black tab.
    • Pull the black tab on the top of the connector to unplug the battery from the motherboard.
  8. Dell Latitude 7390 SSD Replacement: passo 8, immagine 1 di 1
    • Carefully lift the battery out of the laptop.
  9. Dell Latitude 7390 SSD Replacement, Solid State Drive (SSD): passo 9, immagine 1 di 1
    • Using a Phillips screwdriver, remove the 6 mm screw from the SSD cover.
  10. Dell Latitude 7390 SSD Replacement: passo 10, immagine 1 di 1
    • Remove the SSD card from under the silver plate.
Conclusione
Thomas Pryor
Membro da: 02/22/22
86 Reputazione
1 Guida realizzata
Clemson, Team 1-4, Hunter Spring 2022 Membro di Clemson, Team 1-4, Hunter Spring 2022
CLEM-HUNTER-S22S1G4
5 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 66
Tutti i Tempi: 2,967
