Salta al contenuto principale
Dell Latitude 5580 Motherboard Replacement
Cosa ti serve
  1. Dell Latitude 5580 Motherboard Replacement, Lower Case: passo 1, immagine 1 di 3 Dell Latitude 5580 Motherboard Replacement, Lower Case: passo 1, immagine 2 di 3 Dell Latitude 5580 Motherboard Replacement, Lower Case: passo 1, immagine 3 di 3
    • Orient your laptop so that you have access to the lower case, with the vents facing upwards.
    • Use a Phillips screwdriver to loosen the eight screws securing the bottom cover.
    • They are captive screws and do not fully come out of the holes. Don't force them or you may damage the screws or holes on the bottom case.
    • Insert the end of an iFixit opening tool or an opening pick into the seam between the bottom and top case to release the clips holding them together.
    • Slide the opening tool or pick around the edge of the laptop until the case is fully released.
    • Remove the lower case.
  2. Dell Latitude 5580 Motherboard Replacement, Battery: passo 2, immagine 1 di 3 Dell Latitude 5580 Motherboard Replacement, Battery: passo 2, immagine 2 di 3 Dell Latitude 5580 Motherboard Replacement, Battery: passo 2, immagine 3 di 3
    • Orient your laptop so that you have access to the bottom cover, with the fan vents facing upwards.
    • Use a Phillips #00 screwdriver to loosen the eight screws securing the bottom cover.
    • Insert the end of an iFixit opening tool or opening picks into the seam between the bottom and top case to release the clips holding them together.
    • Slide the opening tool or pick around the edge of the laptop until it is fully separated.
    • Remove the bottom cover.
  3. Dell Latitude 5580 Motherboard Replacement: passo 3, immagine 1 di 3 Dell Latitude 5580 Motherboard Replacement: passo 3, immagine 2 di 3 Dell Latitude 5580 Motherboard Replacement: passo 3, immagine 3 di 3
    • Remove the single Phillips #00 screw that is holding down the battery.
  4. Dell Latitude 5580 Motherboard Replacement: passo 4, immagine 1 di 2 Dell Latitude 5580 Motherboard Replacement: passo 4, immagine 2 di 2
    • Use the pull tab to gently pull the battery cable out of its socket.
  5. Dell Latitude 5580 Motherboard Replacement: passo 5, immagine 1 di 2 Dell Latitude 5580 Motherboard Replacement: passo 5, immagine 2 di 2
    • Remove the old battery.
    • To install the battery connection cable, push gently into the original connection port to connect the replacement battery to the computer. Tuck in the battery connection cable underneath the plastic frame next to the battery.
  6. Dell Latitude 5580 Motherboard Replacement, Motherboard: passo 6, immagine 1 di 2 Dell Latitude 5580 Motherboard Replacement, Motherboard: passo 6, immagine 2 di 2
    • Disconnect and remove the CMOS battery.
    • Pull it out carefully as to not damage any pins in the process.
  7. Dell Latitude 5580 Motherboard Replacement: passo 7, immagine 1 di 3 Dell Latitude 5580 Motherboard Replacement: passo 7, immagine 2 di 3 Dell Latitude 5580 Motherboard Replacement: passo 7, immagine 3 di 3
    • Unscrew the four screws securing the hard drive with a Phillips screwdriver.
    • Remove the hard drive with your hand.
    • Keep track of these four screws as they are unique to the hard drive.
  8. Dell Latitude 5580 Motherboard Replacement: passo 8, immagine 1 di 3 Dell Latitude 5580 Motherboard Replacement: passo 8, immagine 2 di 3 Dell Latitude 5580 Motherboard Replacement: passo 8, immagine 3 di 3
    • Remove all 3.4 mm-long screws securing the midframe and slowly take it out, unseating the Wi-Fi antenna cables in the process.
  9. Dell Latitude 5580 Motherboard Replacement: passo 9, immagine 1 di 3 Dell Latitude 5580 Motherboard Replacement: passo 9, immagine 2 di 3 Dell Latitude 5580 Motherboard Replacement: passo 9, immagine 3 di 3
    • Remove the screws securing the metal brackets holding the power connectors with a Phillips screwdriver.
    • Remove the brackets.
    • With your hand, pull the black pull tab directly up to disconnect it.
  10. Dell Latitude 5580 Motherboard Replacement: passo 10, immagine 1 di 1
    • Unscrew the bracket above the type-C USB port held in by two phillips screws.
    • Using your hand, set it aside.
  11. Dell Latitude 5580 Motherboard Replacement: passo 11, immagine 1 di 3 Dell Latitude 5580 Motherboard Replacement: passo 11, immagine 2 di 3 Dell Latitude 5580 Motherboard Replacement: passo 11, immagine 3 di 3
    • Remove the two Phillips screws securing the fan.
    • Disconnect the fan connector.
    • Remove the fan.
  12. Dell Latitude 5580 Motherboard Replacement: passo 12, immagine 1 di 3 Dell Latitude 5580 Motherboard Replacement: passo 12, immagine 2 di 3 Dell Latitude 5580 Motherboard Replacement: passo 12, immagine 3 di 3
    • Using your hand, flip up the locking flaps and detach the touchpad ribbon cables connected to the motherboard.
    • Detach the power cables for the speakers using the tweezers.
    • Flip up the locking flap and disconnect the ribbon cables for the keyboard LED interface with your hand.
    • You can remove the RAM, Wi-Fi card and CPU heatsink, but it is not required to do so in order to take the motherboard out.
  13. Dell Latitude 5580 Motherboard Replacement: passo 13, immagine 1 di 2 Dell Latitude 5580 Motherboard Replacement: passo 13, immagine 2 di 2
    • Remove the remaining five screws holding the motherboard to the chassis.
    • With your hand, remove the motherboard from the chassis.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Levi H
Membro da: 09/08/25
181 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 44
Tutti i Tempi: 198
