Salta al contenuto principale
Dell Latitude 3500 Power Button Board Replacement
Cosa ti serve
  1. Dell Latitude 3500 Power Button Board Replacement, Remove screws: passo 1, immagine 1 di 1
    • 10 screws hold the bottom cover in place -- these stay in the bottom cover.
  2. Dell Latitude 3500 Power Button Board Replacement, Separate bottom cover and palmrest: passo 2, immagine 1 di 1
    • Using a spudger will make quick work of this step.
  3. Dell Latitude 3500 Power Button Board Replacement, Disconnect and Remove Battery: passo 3, immagine 1 di 1
    • Disconnect the battery cable from the motherboard.
    • Remove the 4 screws holding it in place
    • Battery can now be removed from device.
  4. Dell Latitude 3500 Power Button Board Replacement, Disconnect Surrounding Connections from System Fan: passo 4, immagine 1 di 1
    • Unplug the fan header
    • Unplug the VGA board cable
    • Unplug the LCD cable
  5. Dell Latitude 3500 Power Button Board Replacement, Remove Fan Screws: passo 5, immagine 1 di 1
    • Once these 2 screws are removed the fan will lift out as long as the cables are out of the way.
  6. Dell Latitude 3500 Power Button Board Replacement, Disconnect Ribbon Cable: passo 6, immagine 1 di 1
    • Insert wisdom here.
  7. Dell Latitude 3500 Power Button Board Replacement, Lift Left-Side Hinge: passo 7, immagine 1 di 1
    • 2 screws total
  8. Dell Latitude 3500 Power Button Board Replacement, Remove Board: passo 8, immagine 1 di 1
    • 2 screws total
Conclusione
Jake
Membro da: 03/08/23
1.300 Reputazione
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 8
Tutti i Tempi: 36
