Salta al contenuto principale
Dell Latitude 3450 RAM Replacement
Cosa ti serve
Panoramica Video
  1. Dell Latitude 3450 RAM Replacement, Getting Started: passo 1, immagine 1 di 2 Dell Latitude 3450 RAM Replacement, Getting Started: passo 1, immagine 2 di 2
    • Ensure the laptop is powered off .
    • Flip the laptop over.
  2. Dell Latitude 3450 RAM Replacement, Removing the Rear Cover: passo 2, immagine 1 di 3 Dell Latitude 3450 RAM Replacement, Removing the Rear Cover: passo 2, immagine 2 di 3 Dell Latitude 3450 RAM Replacement, Removing the Rear Cover: passo 2, immagine 3 di 3
    • Loosen the two Phillips head screws.
    • These screws should back out, but should not actually be removable.
    • Locate the indent on the rear cover half way between the two Phillips head screws.
    • Insert your spudger to help pry up the rear cover.
    • It may be necessary to run the spudger along the side with the indent to help release the clips
    • Lift off the rear cover.
  3. Dell Latitude 3450 RAM Replacement, Installing the RAM: passo 3, immagine 1 di 3 Dell Latitude 3450 RAM Replacement, Installing the RAM: passo 3, immagine 2 di 3 Dell Latitude 3450 RAM Replacement, Installing the RAM: passo 3, immagine 3 di 3
    • The RAM slots are in line with the hard drive, and on the right side if the cover was opened away from you.
    • Please note that there are A and B RAM Slots. There must be a RAM chip in the A Slot, or the laptop will not load normally.
    • The Slots are labeled on the board, under where the chips would normally be seated.
    • Ensure that the space in the RAM chip lines up with alignment pin on the slot.
    • Insert the RAM chip at approximately at 45° angle.
    • Once the chip bottoms out on the slot, push down on the opposite side from the pins until the RAM chip seats on the board.
    • Depending on your machines current configuration, you may need to remove a RAM chip before you can insert your new ones.
    • Using your finger nail or a spudger, push the lock clips off the RAM chip.
    • Normally the clips can be done one at a time, but may require you to release both at once.
    • Once released, the chip should spring up and can be removed.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 24
Tutti i Tempi: 2,278
