Salta al contenuto principale
Dell Latitude 3189 SSD Replacement
Cosa ti serve
  1. Dell Latitude 3189 SSD Replacement, Lower Case: passo 1, immagine 1 di 2 Dell Latitude 3189 SSD Replacement, Lower Case: passo 1, immagine 2 di 2
    • Before beginning, power off and unplug the device.
    • Use a Phillips screwdriver to loosen the seven captive screws that secure the lower case.
  2. Dell Latitude 3189 SSD Replacement: passo 2, immagine 1 di 3 Dell Latitude 3189 SSD Replacement: passo 2, immagine 2 di 3 Dell Latitude 3189 SSD Replacement: passo 2, immagine 3 di 3
    • Insert a nylon spudger between the lower case and chassis at the two hinge spaces on the back side of the laptop and pry up the lower case.
    • Do not use metal items to pry the base cover off, like a screwdriver, as it could slip and damage internal components.
    • Avoid prying at the ports.
  3. Dell Latitude 3189 SSD Replacement: passo 3, immagine 1 di 2 Dell Latitude 3189 SSD Replacement: passo 3, immagine 2 di 2
    • Grip and lift the lower case up and away.
    • If you feel any significant resistance, double check that all of the screws are loosened.
  4. Dell Latitude 3189 SSD Replacement: passo 4, immagine 1 di 3 Dell Latitude 3189 SSD Replacement: passo 4, immagine 2 di 3 Dell Latitude 3189 SSD Replacement: passo 4, immagine 3 di 3
    • Before performing any operations within the laptop, unplug the battery.
    • Pull the white battery connector directly out of its motherboard port.
    • Do not pull on the wires.
  5. Dell Latitude 3189 SSD Replacement, SSD: passo 5, immagine 1 di 2 Dell Latitude 3189 SSD Replacement, SSD: passo 5, immagine 2 di 2
    • Use a Phillips screwdriver to remove the single 3.2 mm screw that secures the SSD.
    • The SSD will pop up a few millimeters; this is normal.
  6. Dell Latitude 3189 SSD Replacement: passo 6, immagine 1 di 1
    • Gently pull the SSD out of its socket, maintaining the same angle that it flipped up to.
    • Do not pull directly up on the SSD after the screw is removed as you could damage the SSD and/or the connector.
Conclusione
Altre 3 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 29
Tutti i Tempi: 414
