Introduzione
In order to perform any repairs in the Dell Latitude 3189, you will need to open up the base cover. Use this guide to open up the base cover in order to perform any internal repairs.
The screws on the base cover are captive, which means you won't have to track any screws for this guide. In step 2, when prying at the base cover to remove it, avoid using metal implements, such as a screwdriver, as you could slip and damage internal components.
Before using this guide, completely power down the device, and unplug any cords or devices in any ports.
Cosa ti serve
Use a Phillips screwdriver to loosen the seven captive screws that secure the lower case.
