Salta al contenuto principale
Dell Inspiron n5110 Display Assembly Replacement
Cosa ti serve
  1. Dell Inspiron n5110 Display Assembly Replacement, Remove the Screws: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the display assembly to the computer base.
  2. Dell Inspiron n5110 Display Assembly Replacement, Disconnecting the Display Cable: passo 2, immagine 1 di 1
    • Disconnect the display cable and touch-screen cable from the system-board connectors.
    • NOTE: The touch-screen board is optional and may not be present in your computer.
  3. Dell Inspiron n5110 Display Assembly Replacement, Note the Routing: passo 3, immagine 1 di 1
    • Note the routing of the Mini-Card antenna cables and remove the cables from the routing guides.
  4. Dell Inspiron n5110 Display Assembly Replacement, Remove the Screws: passo 4, immagine 1 di 1
    • Remove the four screws that secure the display assembly to the computer base.
  5. Dell Inspiron n5110 Display Assembly Replacement, Lifting the Display Assembly.: passo 5, immagine 1 di 1
    • Lift the display assembly off the computer base.
  6. Dell Inspiron n5110 Display Assembly Replacement, Placing the Display Assembly: passo 6, immagine 1 di 1
    • Place the NEW display assembly in position and replace the four screws that secure the display assembly to the computer base.
  7. Dell Inspiron n5110 Display Assembly Replacement, Route the Cables: passo 7, immagine 1 di 1
    • Route the Mini-Card antenna cables through the routing guides.
  8. Dell Inspiron n5110 Display Assembly Replacement, Connect the Display Cable: passo 8, immagine 1 di 1
    • Connect the display cable and touch-screen cable to the connectors on the system board.
  9. Dell Inspiron n5110 Display Assembly Replacement, Replace the Screws: passo 9, immagine 1 di 1
    • Replace the two screws that secure the display assembly to the computer base.
Linea Traguardo
Altre 3 persone hanno completato questa guida.
Terrence15
Membro da: 12/18/17
79.243 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 24
Tutti i Tempi: 2,097
