Salta al contenuto principale
Dell Inspiron n5110 Battery Replacement
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Shut down the computer and turn it over.
  1. Dell Inspiron n5110 Battery Replacement, Sliding the Latch: passo 2, immagine 1 di 1
    • Slide the battery release latch and the battery lock latch to the unlock positions.
  2. Dell Inspiron n5110 Battery Replacement, Lifting the Battery: passo 3, immagine 1 di 1
    • Slide and lift the battery out of the battery bay.
  3. Dell Inspiron n5110 Battery Replacement, Sliding the Battery: passo 4, immagine 1 di 1
    • Slide the NEW battery into the battery bay until it clicks into place.
  4. Dell Inspiron n5110 Battery Replacement, Sliding the Battery Latch: passo 5, immagine 1 di 1
    • Slide the battery lock latch to the lock position.
Linea Traguardo
Altre 4 persone hanno completato questa guida.
Terrence15
Membro da: 12/18/17
79.243 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,188
