Salta al contenuto principale
Introduzione
The keyboard needs to be removed to access everything (hard drive, optical drive, RAM, motherboard).
  1. Flip your laptop over to view the bottom and locate the two locks.
    • Flip your laptop over to view the bottom and locate the two locks.
  2. Slide the two locks away from each other.
    • Slide the two locks away from each other.
    • Sliding these locks will loosen the battery to allow removal.
  3. Kit di riparazione batterie iPhone
    Solo $29.99
    Buy Now
    Solo $29.99
    Buy Now
  4. Pull battery out of the laptop. Your laptop's battery should be completely removed.
    • Pull battery out of the laptop.
    • Your laptop's battery should be completely removed.
  5. Flip the laptop right side up.  Open the laptop. Gently press in the four retaining tabs along the top of the keyboard with a spudger, one at a time.
    • Flip the laptop right side up. Open the laptop.
    • Gently press in the four retaining tabs along the top of the keyboard with a spudger, one at a time.
    • After the first tab is released, gently lift up on the keyboard so it doesn't lock again. Finish the other three tabs while gently lifting up on the keyboard. The keyboard will hinge up along the bottom.
  6. Gently flip the data cable latch away from the data cable with flat side of spudger. Lift the cable up and out. When reinstalling cable, there are two retainer wings on the sides of the cable that the cable that lock onto the bottom of the cable latch area.  When these are in place the cable is properly inserted.
    • Gently flip the data cable latch away from the data cable with flat side of spudger.
    • Lift the cable up and out.
    • When reinstalling cable, there are two retainer wings on the sides of the cable that the cable that lock onto the bottom of the cable latch area. When these are in place the cable is properly inserted.
    • For removing the optical drive you don't need to disconnect the keyboard ribbon cable.
Conclusione
Altre 4 persone hanno completato questa guida.
Tyler
Membro da: 19/06/2012
4.318 Reputazione
16 Guide realizzate
TechForce Membro di TechForce
Business
2 Membri
18 Guide realizzate
dis has realy helped me sir... love you!
jovialcom - Replica
Dell Inspiron 15 - M5040 N5040 N5050 disassembly
https://youtu.be/3c5P0pJgckg
mohamed - Replica
Here’s a video guide to replacing the keyboard on this (or similar) laptop: https://www.youtube.com/watch?v=6T3xgkC-...
Paul Freeman-Powell - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 38
Tutti i Tempi: 8,266
