Salta al contenuto principale
Dell Inspiron One 2020 Hard Drive Replacement
Cosa ti serve
  1. Dell Inspiron One 2020 Hard Drive Replacement, Back Cover: passo 1, immagine 1 di 3 Dell Inspiron One 2020 Hard Drive Replacement, Back Cover: passo 1, immagine 2 di 3 Dell Inspiron One 2020 Hard Drive Replacement, Back Cover: passo 1, immagine 3 di 3
    • Place the all in one computer face down on a soft, clean surface to avoid scratching the front.
    • Press the tab on the stand cover and lift up.
  2. Dell Inspiron One 2020 Hard Drive Replacement: passo 2, immagine 1 di 3 Dell Inspiron One 2020 Hard Drive Replacement: passo 2, immagine 2 di 3 Dell Inspiron One 2020 Hard Drive Replacement: passo 2, immagine 3 di 3
    • Remove the four phillips screws that attach the stand to the computer.
    • Tilt the stand up and out.
  3. Dell Inspiron One 2020 Hard Drive Replacement: passo 3, immagine 1 di 3 Dell Inspiron One 2020 Hard Drive Replacement: passo 3, immagine 2 di 3 Dell Inspiron One 2020 Hard Drive Replacement: passo 3, immagine 3 di 3
    • Starting from the optical drive, pry the back cover up with a plastic spudger.
    • The cover is held in place by fragile plastic clips. Careful to not break them.
  4. Dell Inspiron One 2020 Hard Drive Replacement, Hard Drive: passo 4, immagine 1 di 2 Dell Inspiron One 2020 Hard Drive Replacement, Hard Drive: passo 4, immagine 2 di 2
    • Remove the three screws that hold the hard drive cage to the chassis.
  5. Dell Inspiron One 2020 Hard Drive Replacement: passo 5, immagine 1 di 2 Dell Inspiron One 2020 Hard Drive Replacement: passo 5, immagine 2 di 2
    • Slide the hard drive cage out slightly to access and remove the power and SATA cable.
    • There isn't much slack in these cables, so don't slide the hard drive cage to far.
    • The power and SATA cables are connected together. On most other computers, these connectors are separate.
    • Lift the hard drive cage out.
  6. Dell Inspiron One 2020 Hard Drive Replacement: passo 6, immagine 1 di 3 Dell Inspiron One 2020 Hard Drive Replacement: passo 6, immagine 2 di 3 Dell Inspiron One 2020 Hard Drive Replacement: passo 6, immagine 3 di 3
    • Remove the four screws (two on each side) that attach the hard drive cage to the hard drive.
    • Lift the hard drive cage off the hard drive.
    Excellent guide, was a super easy swap. I put an SSD in it!!
    Matt Yakel - Replica
    Hey Just one question, is the HDD SATA 2 or SATA 3? Just wanted to know so I can purchase an SDD with the correct specification.
    Jeffery Epstein - Replica
Conclusione
Altre 35 persone hanno completato questa guida.
Tyler
Membro da: 06/19/12
4.920 Reputazione
16 Guide realizzate
TechForce Membro di TechForce
Business
2 Membri
25 Guide realizzate
3 Commenti
Thanks for this info this is very useful
Thank you once again
Ketan Valsangkar - Replica
Good Job, short and sweet and easy to follow
schmidtrg - Replica
Really useful information thank you.
Jessie Colon - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 78
Tutti i Tempi: 35,722
