Introduzione
WiFi & Blue-tooth mini PCI card replacement. To change the Wifi card on this model you must to remove the upper case of the laptop. This is not a good engineering designee. We will show you how to do this.
Cosa ti serve
Panoramica Video
Switch off the laptop and remove the battery.
The keyboard is held by 4x locking clips.
By using cutter, carefully lift up the one side of the keyboard and start opening the locking clips.
Here is the Wi-Fi card
Disconnect the antenna cable connectors
Remove the Wi-Fi card
Altre 4 persone hanno completato questa guida.
2 Commenti
Great, cogent step by step. You alleviated the need to watch a video while including all of the key steps. Nicely done. I replaced a hard drive last year and I would have preferred this format.
Hi, do you know if there is a whitelist for wifi adapters in this notebook?
