Salta al contenuto principale
Dell Inspiron N5050 RAM Replacement
Cosa ti serve
  1. Dell Inspiron N5050 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Flip your laptop over to view the bottom and the two locks.
    How many gb hard drive can I install on Inspiron n5050
    Anguiano pro - Replica
  2. Dell Inspiron N5050 RAM Replacement: passo 2, immagine 1 di 1
    • Slide the two locks away from each other.
    • Sliding these locks will loosen the battery to allow removal.
  3. Dell Inspiron N5050 RAM Replacement: passo 3, immagine 1 di 2 Dell Inspiron N5050 RAM Replacement: passo 3, immagine 2 di 2
    • Pull the battery out of the laptop.
    • Your laptop's battery should be completely removed.
  4. Dell Inspiron N5050 RAM Replacement, RAM: passo 4, immagine 1 di 1
    • Remove the eleven 5mm palmrest screws from the bottom of the laptop with a Phillips #PH00 screw.
    • Remove the two 3mm hard drive screws from the bottom of the laptop with a Phillips #PH00 screw.
  5. Dell Inspiron N5050 RAM Replacement: passo 5, immagine 1 di 2 Dell Inspiron N5050 RAM Replacement: passo 5, immagine 2 di 2
    • Flip over and open the laptop to view the keyboard.
    • Use a plastic opening tool to press down on four clips, one by one.
    • Press down on the clips and pull the tool towards you to pry the keyboard loose.
    • The four clips are above the Esc, F6, F11, and Delete keys.
  6. Dell Inspiron N5050 RAM Replacement: passo 6, immagine 1 di 3 Dell Inspiron N5050 RAM Replacement: passo 6, immagine 2 di 3 Dell Inspiron N5050 RAM Replacement: passo 6, immagine 3 di 3
    • Remove the keyboard carefully.
    • Make sure to lift the keyboard gently, because a cable is connected to the back.
    • Flip the keyboard over to find the keyboard cable.
    • Pull the cable labeled "UP" out to disconnect it from the laptop.
  7. Dell Inspiron N5050 RAM Replacement: passo 7, immagine 1 di 3 Dell Inspiron N5050 RAM Replacement: passo 7, immagine 2 di 3 Dell Inspiron N5050 RAM Replacement: passo 7, immagine 3 di 3
    • Find the RAM and pull apart the two clips.
    • After pulling apart both clips, the RAM component will snap up.
  8. Dell Inspiron N5050 RAM Replacement: passo 8, immagine 1 di 2 Dell Inspiron N5050 RAM Replacement: passo 8, immagine 2 di 2
    • Remove the RAM.
Conclusione
Altre 7 persone hanno completato questa guida.
Un commento
Thanks Kristy,
I was breath new life back into an old laptop and re-purpose after upgrading the RAM.
jason acn - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,330
