Introduzione
If you want to upgrade your computer by putting in new RAM, or if you need to replace your RAM with new boards, use this guide to learn how to do it.
Cosa ti serve
Turn the computer over on its back so the battery compartment faces towards you.
Place your fingers on the small buttons with arrows pointing outwards.
Push and slide the buttons outward to unlock the battery compartment.
Use a Phillips #0 screwdriver to unscrew the sixteen 0.6 mm screws on the back panel.
Place your fingers on the two metal tabs on the edges of the RAM.
Push on the tabs in the opposite direction.
Altre 5 persone hanno completato questa guida.
3 Commenti
Looking at the Dell service manual. You dont need to remove any screws, but only the keyboard, and if your careful you dont need to remove the ribbon cable. Its all in the service manual you can download free from Dell.
зависит от целей. озу можно поменять не разбирая всё. а вот пзу придется все разобрать. я так и не понял сьёмный тут проц или припаян. вроде есть защелка
