Salta al contenuto principale
Dell Inspiron N5030 Display Assembly Replacement
Cosa ti serve
  1. Dell Inspiron N5030 Display Assembly Replacement, Remove the Screws: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the display assembly to the base of the computer.
  2. Dell Inspiron N5030 Display Assembly Replacement, Open the Display: passo 2, immagine 1 di 1
    • Turn the computer over and open the display as far as possible.
  3. Dell Inspiron N5030 Display Assembly Replacement, Disconnect the Cable: passo 3, immagine 1 di 1
    • Make a note of the Wireless Mini-Card antenna cable routing and disconnect the Wireless Mini-Card antenna cable from the Wireless Mini- Card.
  4. Dell Inspiron N5030 Display Assembly Replacement, Disconnect the Display Cable: passo 4, immagine 1 di 1
    • Disconnect the display cable from the connector on the system board and remove it from the routing guide.
  5. Dell Inspiron N5030 Display Assembly Replacement, Remove the Screws: passo 5, immagine 1 di 1
    • Remove the two screws (one on each side) that secure the display assembly to the computer base.
  6. Dell Inspiron N5030 Display Assembly Replacement, Remove the Display Assembly: passo 6, immagine 1 di 1
    • Lift and remove the display assembly out of the computer base.
  7. Dell Inspiron N5030 Display Assembly Replacement, Placing the Display Assembly: passo 7, immagine 1 di 1
    • Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
  8. Dell Inspiron N5030 Display Assembly Replacement, Routing the Display Cable: passo 8, immagine 1 di 1
    • Route the display cable into the routing guide and connect the display cable to the connector on the system board.
  9. Dell Inspiron N5030 Display Assembly Replacement, Routing the Antenna Cable: passo 9, immagine 1 di 1
    • Route the Mini-Card antenna cable into the routing guide and connect the Mini-Card antenna cable to the connector on the Mini-Card.
  10. Dell Inspiron N5030 Display Assembly Replacement, Replace the Screws: passo 10, immagine 1 di 1
    • Turn the computer over and replace the two screws at the base of the computer.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.091 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 373
