Salta al contenuto principale
Dell Inspiron N5030 Disc Drive Replacement
Cosa ti serve
  1. Dell Inspiron N5030 Disc Drive Replacement, Battery: passo 1, immagine 1 di 2 Dell Inspiron N5030 Disc Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the computer over on its back so the battery compartment faces towards you.
    • Place your fingers on the small buttons with arrows pointing outwards.
    • Push and slide the buttons outward to unlock the battery compartment.
  2. Dell Inspiron N5030 Disc Drive Replacement: passo 2, immagine 1 di 2 Dell Inspiron N5030 Disc Drive Replacement: passo 2, immagine 2 di 2
    • Grab the battery and pull it towards yourself.
    • Remove the battery.
  3. Dell Inspiron N5030 Disc Drive Replacement, Keyboard: passo 3, immagine 1 di 1
    • Use a Phillips #0 screwdriver to unscrew the sixteen 0.6 mm screws on the back panel.
  4. Dell Inspiron N5030 Disc Drive Replacement: passo 4, immagine 1 di 1
    • Flip over the laptop and open it so that the screen faces you.
  5. Dell Inspiron N5030 Disc Drive Replacement: passo 5, immagine 1 di 1
    • Use the plastic opening tool and your fingers to pry off the top panel.
    • Pry the panel off starting at any one of the corners and then continue around the edges of the computer.
  6. Dell Inspiron N5030 Disc Drive Replacement: passo 6, immagine 1 di 1
    • Be careful when lifting off the keyboard panel. There are multiple delicate cables connecting the panel to the motherboard.
    • Pull up on the blue plastic tab connected by the white strip to unhook the keyboard panel from the motherboard.
  7. Dell Inspiron N5030 Disc Drive Replacement: passo 7, immagine 1 di 1
    • Flip up the small locking flap on the keyboard cable ZIF socket and disconnect the keyboard ribbon cable.
  8. Dell Inspiron N5030 Disc Drive Replacement: passo 8, immagine 1 di 1
    • Pull up on the wire tab with the blue, white, black, and red wires to detach the speakers from the motherboard.
  9. Dell Inspiron N5030 Disc Drive Replacement: passo 9, immagine 1 di 1
    • Remove the top keyboard panel.
  10. Dell Inspiron N5030 Disc Drive Replacement, Disc Drive: passo 10, immagine 1 di 1
    • Use a Phillips #0 screwdriver to unscrew one 0.6 mm screw located just to the left of the disc drive.
  11. Dell Inspiron N5030 Disc Drive Replacement: passo 11, immagine 1 di 1
    • Position your thumbs to push firmly and slide the disc drive to the right through the rectangular hole in the side of the laptop and out.
Conclusione
Altre 3 persone hanno completato questa guida.
Charles
Membro da: 04/22/14
579 Reputazione
2 Guide realizzate
Cal Poly, Team 10-59, Amido Spring 2014 Membro di Cal Poly, Team 10-59, Amido Spring 2014
CPSU-AMIDO-S14S10G59
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,029
