Salta al contenuto principale
Dell Inspiron N4110 Screen Replacement
Cosa ti serve
  1. Dell Inspiron N4110 Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the laptop is off and unplugged before starting this step.
    • Locate the battery on the underside of the laptop.
    • Push the two battery clips following the direction of the arrows.
  2. Dell Inspiron N4110 Screen Replacement: passo 2, immagine 1 di 1
    • Push upward from the base of the battery.
  3. Dell Inspiron N4110 Screen Replacement: passo 3, immagine 1 di 1
    • Pull battery away from computer until it is fully removed.
  4. Dell Inspiron N4110 Screen Replacement, Screen: passo 4, immagine 1 di 3 Dell Inspiron N4110 Screen Replacement, Screen: passo 4, immagine 2 di 3 Dell Inspiron N4110 Screen Replacement, Screen: passo 4, immagine 3 di 3
    • Use your hands to remove the plastic cover from around the screen.
    • This can seem difficult, but it can be done.
  5. Dell Inspiron N4110 Screen Replacement: passo 5, immagine 1 di 2 Dell Inspiron N4110 Screen Replacement: passo 5, immagine 2 di 2
    • Unscrew the two 2.5x4 mm screws from the top of the screen.
  6. Dell Inspiron N4110 Screen Replacement: passo 6, immagine 1 di 2 Dell Inspiron N4110 Screen Replacement: passo 6, immagine 2 di 2
    • Loosen the four 2.5x4 mm screws from the base of the screen.
    • This will allow the screen to lift from inside the top of the case.
  7. Dell Inspiron N4110 Screen Replacement: passo 7, immagine 1 di 3 Dell Inspiron N4110 Screen Replacement: passo 7, immagine 2 di 3 Dell Inspiron N4110 Screen Replacement: passo 7, immagine 3 di 3
    • Unscrew the four 2x3 mm screws from the two sides on both the top and bottom.
  8. Dell Inspiron N4110 Screen Replacement: passo 8, immagine 1 di 2 Dell Inspiron N4110 Screen Replacement: passo 8, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to peel the webcam away from the top of the laptop.
    • The webcam is only held in place by a webcam, this is easy to pull away from the screen.
  9. Dell Inspiron N4110 Screen Replacement: passo 9, immagine 1 di 3 Dell Inspiron N4110 Screen Replacement: passo 9, immagine 2 di 3 Dell Inspiron N4110 Screen Replacement: passo 9, immagine 3 di 3
    • Lift the adhesive flap from the cord that connects the computer to the screen.
    • You can then disconnect the cord from the screen.
  10. Dell Inspiron N4110 Screen Replacement: passo 10, immagine 1 di 1
    • The screen can now be fully removed from the computer.
Conclusione
Abigail Keith
Membro da: 03/20/18
505 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,248
