Salta al contenuto principale
Dell Inspiron N4110 RAM Replacement
Cosa ti serve
  1. Dell Inspiron N4110 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the laptop is off and unplugged before starting this step.
    • Locate the battery on the underside of the laptop.
    • Push the two battery clips following the direction of the arrows.
  2. Dell Inspiron N4110 RAM Replacement: passo 2, immagine 1 di 1
    • Push upward from the base of the battery.
  3. Dell Inspiron N4110 RAM Replacement: passo 3, immagine 1 di 1
    • Pull battery away from computer until it is fully removed.
  4. Dell Inspiron N4110 RAM Replacement, RAM: passo 4, immagine 1 di 2 Dell Inspiron N4110 RAM Replacement, RAM: passo 4, immagine 2 di 2
    • Locate and unscrew the one 2.5x5 mm screw on the cover.
    • The screw does not detach from the cover. Make sure the screw is fully unscrewed before attempting to remove the cover.
  5. Dell Inspiron N4110 RAM Replacement: passo 5, immagine 1 di 2 Dell Inspiron N4110 RAM Replacement: passo 5, immagine 2 di 2
    • Remove RAM cover from the laptop.
  6. Dell Inspiron N4110 RAM Replacement: passo 6, immagine 1 di 2 Dell Inspiron N4110 RAM Replacement: passo 6, immagine 2 di 2
    • Use your fingers to separate the two metal clips from the RAM.
    • The RAM will lift up when properly separated. Do not force the RAM out of the clips.
  7. Dell Inspiron N4110 RAM Replacement: passo 7, immagine 1 di 1
    • Remove the RAM from the computer.
    • Be careful as to not touch the metal on the bottom of the RAM. This can cause damage.
    • The RAM should be placed on a non-conductive surface.
Conclusione
Altre 2 persone hanno completato questa guida.
Olivia
Membro da: 03/20/18
773 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 765
